-   -   Diff Oil (https://www.bristolcars.info/forums/showthread.php?t=2316)
Martin9645 13-08-24 12:10 PM
Diff Oil
Can some one please tell me what Diff Oil & Gear Box Oil I should use on a 1970 BRistol 411 Mark 1 with a 3 Speed Auto Box??
many thanks
David C 13-08-24 07:29 PM
ATF+4 and Dexron III seem to be widely recommended for use in the Torqueflite 727. I have chosen Comma MVATF+ as it is readily available from Halfords amongst others.
Do you have a limited slip diff in your back axle?
Martin9645 14-08-24 08:12 AM
[quote=David C;13470]ATF+4 and Dexron III seem to be widely recommended for use in the Torqueflite 727. I have chosen Comma MVATF+ as it is readily available from Halfords amongst others.
Do you have a limited slip diff in your back axle?[/QUOTE
Hi David,
thank you for coming back to me.
Yes the Mark 1 was fitted with a limited slip diff
Many thanks
Martin
David C 16-08-24 07:10 AM
Hello Martin.
I contacted Morris Oils to check what they recommend for your rear axle. They suggest their XEP 80W90 is what you need.
Martin9645 16-08-24 07:41 AM
[quote=Martin9645;13471]
Hi David,
Many thanks
Martin
Originally Posted by David C (Post 13476)
Hello Martin.
Thanks David,
really appreciate all your help.
Kind Regards
Martin
