-   -   Rubber Bellows for 411 Accelerator Pedal (https://www.bristolcars.info/forums/showthread.php?t=2181)
peter dowdle 04-06-23 05:15 AM
Hi
Does anyone know where I might get one of the above? I could make one out of leather or vinyl if I had too.
Regards Peter Dowdle
Kevin H 04-06-23 06:08 AM
What about this?
https://bobsautomobilia.com/shop/ped...948-58-ab-483/
peter dowdle 04-06-23 06:36 AM
Thanks for that
It looks like it could do the job. Possibly shorter than the bristol one but I doubt that matters.
I will try and get some measurements from them and let the Forum know.
Kevin H 04-06-23 11:42 AM
That was the result of a very quick google search. There are others out there made for other cars. With a bit of searching online you might find a better fit.
Thomas591 04-06-23 05:49 PM
You can check the parts list in the resource section: the HELLA rubber works very well.
Thomas
peter dowdle 04-06-23 10:24 PM
Thomas where do I find it in the resources section ? What Hella product am I looking for ?
Regard Peter Dowdle
Thomas591 05-06-23 03:40 AM
Please check the attached screenshot to find the resources section.
When you are in the resource section, click on „All V8 Bristol Cars“.
There you will find a pdf „ V8 Bristol parts sources“.
Thomas
