409 steering idler repair
My inquiry is for the bush, pin and oil seal dimensions to overhaul my steering idler. The 409 has PAS with the ZF steering box as on later models.
I would suppose that they are Imperial measures and that the bushes are Oilite sintered bronze type. I will grease pack on reassembly and use a two lip seal to help keep out the grime. All advice on removal and dismantling appreciated. |
| All times are GMT. The time now is 05:23 PM. |
