Spark plugs for 313/318 small block engine
Please could anyone inform me what is the current equivalent of the "Autolite" A32 spark club specified by Bristol in the workshop manual. I keep going round in circles but can find nothing definite.
Champion mention RN14YC and RN11YC Autolite 65 and 64's also 751s NGK are mention but non seem to be suitable for a 313/318. Thanking you in anticipation, Nick Challacombe |
Autolite 32 replacement spark plugs
AC Delco 84TS Beck Arnley 176-5178 Bosch D8AC Bosch DR8BPX Bosch stk 4226 Champion F62Y Champion F79Y Champion F81Y Champion RF9YC Champion stk 409 Denso MA16P-U Denso stk 5007 General Motors 5612150 Mopar 4339430 Motorcraft BF12 Motorcraft stk 144 NGK AP7FS NGK AP8FS NGK AP9FS NGK stk 1027 NGK stk 2227 Splitfire SM004E From a simple Google |
Not what I required thank you
Thank you Peter, simple google,
I too tried that but fail to understand why 21 plugs from 9 different manufacturers were the equivalent to Bristol Autolite 32 I was looking for a recommendation, not a clue as to which search engine I should use. Thank you all the same. |
Nick
I went on same roundabout as you and ended up with these - NGK BP6S. SLJ who had serviced the car previously had used NGK BP5S's. Am happy with the plugs - mine's a 410 with a 318. Hope this is of some help. Andrew |
I covered many miles in 2 different 410s as daily drives using BP6RS. The same as Andrew suggests, but resistive. Originally using standard ignition, then with Lumenition electronic. No problems with them and would fit them again.
I think I missed out an R and mine are resisted as well - will go and have a look in a mo.
318/313 small block engine spark plugs.
For my sins I bought NGK AP8FS stk 2227 , which will be fitted next week preparing for a tour of the Dale’s. We did Brecon and the Gower last week and I felt the old girl should have all fluids changed and the filters, plugs, and pads including the hand brake pads which after 22 years of ownership and the fact the handle is now vertical need attention. The power steering fitted two years ago is a god send. I have done 60k miles in the beast , the only problem this year has been the Facet Red top fuel pump which occasionally ceases to function after stopping on a up run, but a tap on the body gets it going. I have cleaned the filter but have bought a spare just in case.
Thank you all for your help , including Peter the simple Googler ! |
Glad you've got yourself sorted - sounds like a great couple of trips.
Andrew |
| All times are GMT. The time now is 02:36 AM. |
