405 Door seal
I am in the last phase of a complete restoration of my Bristol 405 (which has taken a few years) and have exhausted all sources for the correct Bristol upper door rubber i.e. the rubber which seals between the door window frame and the body, and am now about to have some of the original 405 door seal made in the marvellous EPDM rubber material.
This seal will be made to the original identical cross section to that as supplied from Bristol Cars in 1979 but in the superior EPDM rubber material. Supplies are expected to be available from about mid to late May 2021 and am now taking orders from those who want to order a set which will be enough for each of the four doors on each car. I would be grateful if you could respond to me as soon as possible with your order so that quantities can be finalised. It should be noted that this offer is a one time offer and won’t be repeated. Price for each set is $AU120.00 for each car set plus freight. Contact me at [email protected] |
| All times are GMT. The time now is 04:03 AM. |
