Newbee question on "older posts"
I was very excited when I found these forums and started to read eagerly. However, in a lot of threads, the first one I can read is not the first post of the thread. E.g. I look at the thread and -despite being on page 1- the first post I see might be numbered #5 or even #12. This is a bit of a pitty, as one can't get the context of the thread.
Am I doing something wrong or is there an option to go to the beginning of the thread I missed? If not, is there a thread archive somewhere? Thanks in advance for answering |
Welcome Aleph.
Shortly after the site was first launched some posts were moved because they were posted in the wrong forum, particularly as many people moved from a simple mail list and were not accustomed to the multi-forum layout. In one or two cases new threads were created by moving posts on the same topic from one or more other threads. However this should only affect a handful of threads. Could you please specify the threads in which you are seeing this problem and I will look into it. Thanks, Kevin |
Thanks Kevin!
This is 4 of them... http://www.bristolcars.info/forums/showthread.php?t=160 http://www.bristolcars.info/forums/showthread.php?t=174 http://www.bristolcars.info/forums/showthread.php?t=144 edit: http://www.bristolcars.info/forums/showthread.php?t=129 Kind regards, Bas |
Bas, I can't see anything wrong with these threads. I have tried logging in as myself and as a test user (a default registered member) and the threads all appear in reverse chronological order (newest first), which is the site default.
What browser type and version are you using? |
Just thought of something!
Bas, what do you have "Display Modes" set to? (see attached screen shot) It should be on "Linear Mode" Regards, Kevin |
| All times are GMT. The time now is 05:44 AM. |
