-   -   403 - "A" frame attachment to differential on back axle (https://www.bristolcars.info/forums/showthread.php?t=1704)
mikebro 15-11-19 03:43 PM
I've got the ("A" frame) Attachment off the car to fit new rubbers to the swivels, and a new oil seal to the ball joint. The swivel rubbers are no problem. My question concerns the oil seal for the ball joint at the rear of the attachment. Is it possible to fit the new seal without splitting the ball joint? Is it possible to split the ball joint without removing the diff from the back axle, which also involves removing the half shafts? If I really do have to take the diff out, it would be good to know of any tips, pitfalls etc. - I have a copy of the service manual, but some first hand knowledge would be much appreciated.
Julian Caples 16-11-19 09:12 AM
Mike
Yes it is possible to fit the "A" frame ball joint seal without removing the diff. With care, lots of patience and lots of rubber grease, it is possible to stretch the seal over the top. Go very slowly and use rubber grease or you will tear the seal.
No it is not possible to split the ball joint without removing the diff - if you fail to successfully stretch the seal over the top, and need to split the joint you have to remove the diff - the ball joint is held on by a large nut inside the diff casting.
Its not actually too bad - you do need to retract the half shafts (disengage them from the diff) but you don't have to remove them. Getting the diff out is best done from above (ie from inside the car).
Like everything Bristol it helps if you have more than the normal number of joints on your arms and fingers: and it will always take 3 times longer than you planned :-)
Best of luck
Julian
mikebro 18-11-19 06:41 PM
Julian, many thanks for your advice. I tried to get rhe new boot over the ball joint yesterday but was not able to stretch it enough. I've now got rhe diff off and and am doing it the hard way. Very grateful for your help. At least I now know that all the effort is actually required!
Christalfa 19-11-25 02:57 PM
I would like to ask for a source for the oil seal for the A frame. Does anyone know where to buy?
Christian
David C 20-11-25 09:15 AM
I recently had a differential serviced by Oliver Penney and he fitted a new seal so may be able to supply or point you in the right direction.
Raymond 27-11-25 11:17 PM
Please forgive my ignorance but I am new to Bristol Cars.
I can quite appreciate the need to replace the swivels due to wear but what happens to the ball joint on the axle? Does it just develop an oil leak or does the ball joint itself require replacement ? Also, how bad is the oil leak and is it an indication that the half shaft seals may also be worn with oil getting onto the rear brakes?
