Shellubrication Chart X560
I found this in my box of stuff which is of passing interest. Many of you have probably seen or have one but I just wanted to share. The valve clearance advice on page 2 is a bit worrying though!
the valve clearance for exhaust matches the WSM for HOT and 400, 401 and early 403. But inlet seems definitely wrong. @all What do you use for the propeller shaft? Hypoid oil 140 like Spirax 140 EP (as mentioned in the manual) or grease like Retinax A? |
| All times are GMT. The time now is 03:43 PM. |
