B400 waterpump lubrication
I expected a grease nipple at the waterpump.
I found a thread with an Allen screw. Is the thread only a dummy because the waterpump has a permanent lubrication? |
Bela,
The Allen screw is only to locate the bearing in the housing , not for lubrication. As you mentioned the shaft and bearing unit is fully sealed and lubricated. Geoff |
Thank you Geoff!
| All times are GMT. The time now is 07:43 PM. |
