-   -   Unsticking brakes 411-S1 (https://www.bristolcars.info/forums/showthread.php?t=1594)
Claude 18-10-18 10:17 AM
Rebuilt 2 miles and 18 years ago, the 411-S1 rear brakes have become sticky from inactivity. Now that I have sorted the overheating (rebuilt the radiator), it's time to move the car. But moving tends to be slightly dragging, and jacking up the rear wheels, it varies... sometimes easy to move, but hard pressing of the brakes tends to find they do not release.
I've been through the forum looking for hints, but appreciate if someone can guide me through the best way to get them less sticky. Do they require removal and refurbishment, or is there a less complicated way to get them working smoothly? If removal, are there tips that would be helpful?
How are the rear calipers removed? I read somewhere that it is more complicated than just unbolting. And if it is not completely locked up, but tends to stick and unstick, is this something that can be lubricated and unstuck, or is it a candidate for rebuild.
All advice welcome.
Kevin H 19-10-18 01:27 PM
Claude,
If your brakes haven't really been used for 18 years, and you have been using mineral brake fluid, they may need rebuilding again.
Mineral brake fluid is hygroscopic - it absorbs moisture from the atmosphere, so it's possible that the skirts of the pistons have corroded, like the attached photo (this is what the pistons from the front calipers in my 411looked like).
There's really only one way to know for sure, take them apart and have a look.
This is what they look like
Resources - Bristol Cars - Owners and Enthusiasts Forum
Kevin H 19-10-18 11:00 PM
Claude, further to my previous post, regardless of the reason your brakes are sticking, if the fluid has been in there for 18 years, the system should be drained, flushed and refilled.
peter dowdle 20-10-18 03:57 AM
411 sticking back brakes
I recently had a similar problem with my 411 mk 2. The back brakes would lock on intermittently . Believing the problem was the calipers I removed them and had them reconditioned. New pad for brakes and hand brake , all should be well. No such luck no change so I looked at the master cylinder. Great difficulty in getting a repair kit but eventually tracked one down in Scotland but it had missing seals which i sourced in Melbourne Australia. The sticking brake problem was gone but other problems lead me to discard the original cylinder and update to a mk 3 unit ( From early Range Rover). Some modifications needed but the brakes are now perfect.
Claude 22-10-18 07:00 AM
Update and progress documentation
On the Bristol Owners Club forum, Roger and Ken both correctly identified the problem, or I should say, nailed at least one problem, there may be more after I address this one. I will repeat my documentation here for the edification of future owners.
The flexible hose by the rear axle is completely blocked. Annoyingly, it looks ancient, whereas the metal lines are all new. So much for paying shops to do the job.
Curiously, the rubber hose looks almost identical to the one I removed from a 1969 Alfa Spider - same thread, same length. Tomorrow I will head to town and buy a replacement rubber hose.
After that, I will need to check calipers, servos and the master cylinder.
DOCUMENTATION: For future 411 (or similar) owners with brake problems like mine:
Supplies:
  • New hardware store oil can (metal tank with pump squirting lever and 1/4" solid tube) See https://www.amazon.co.uk/dp/B000LFTT5Q for an example
  • New hardware store 6mm clear plastic hose (3 metres) and several hose clamps to fit
  • New brake fluid
  • Kunifer brake line (a soft alloy also known as cupro/nickel) 3/16" SAE and male & female flare tube nuts to match the Bristol thread
  • Brake flaring tool that does double flare
Remove the driver's side (RHD) brake tube flare nut (male) from the T section. Temporarily you will be replacing this with a test brake tube flare nut. BTW, if you don't know how to flare Kunifer brake line, it's forgiving and easy to learn. Get the tools and watch a few YouTube videos or buy a case of beer and stop by your brake supply shop half an hour before closing time for a tutorial.
Make up the testing tool:
  • Take a section of the Kunifer brake line (say 300-500mm) and double flare one end with a male tube nut that will go into the T section.
  • Put a similar double flare on the other end and slide the clear plastic hose over. You will need to use the host clamp on top of the flare to keep it from leaking under pressure.
  • Slide the other end of the clear plastic pipe over the oil can and hose clamp it.
  • Fill the oil can with new brake fluid (this is why you buy a new oil can... no contamination)
  • Attach your fluid testing pump tool to the T section. Make sure it is tight.
Begin testing
  • Open the bleeder valve on the opposing side of the rear axle (left/passenger side on RHD). Attach a hose into a clear glass jar on the ground that you can see from your side.
  • Pump the can. If fluid comes out on the opposing side, you know the rear axle lines are not blocked. You might as well keep pumping until the fluid is clear, you're doing the equivalent of a bench bleed.
  • Close bleeder valve
  • At the front end of the car in the battery compartment, disconnect the battery to avoid sparks and then disconnect the brake line leading into the servo that connects to the rear brakes and pump again. If you are unsure which servo, climb under the car and follow it from the back to the battery compartment.
  • In theory this would reverse flow brake fluid forward until it dripped out (have a cup or big towel ready to catch pumping brake fluid (or make up and attach a female nut to metal line to plastic hose to glass jar)
  • If it does nothing (no flow from the front brake line), remove the rubber flex hose that connects the body brake line to the axle brake line. This probably is the culprit (it was for me). Try blowing air through it. If no air, you know it is junk.
  • Then hook the testing pump to the metal brake line in the battery compartment . If fluid flows out of the rear line where you removed the rubber hose, you can presume the metal line is OK.
  • You can also mechanically test this if you have a new stainless steel bicycle brake cable wire that you slide inside the car's metal brake lines. It should come out the other end clean and with no resistance.
When doing this job, make sure you know where to buy replacement Kunifer brake lines and matching nuts because most cars will not come apart easily. Nuts may strip, or if frozen may twist the old metal lines, requiring replacement. A brake supply house should carry both the metal lines and the rubber hose. Surprisingly, my 1970 411-S1 hose seems almost identical to my 1969 Alfa 1750 hose. Well, maybe not so surprising, since the brake shop matched up the Alfa ones last year and found they were for a "H808 Hose Austin/Bedford/Hillman"
More reports to come, although it will be great if this and a fluid flush/bleed solves it.
Kevin H 23-10-18 10:47 AM
My view is one should begin by bleeding the system as one would do normally, without all the surplus paraphernalia. The brake pedal along with the brake boosters produce at least 1500 psi of hydraulic pressure through the brake lines - far more than any oil can; so if this doesn't force brake fluid through the bleed screws, you know you have a blockage somewhere. If you get fluid flow through the bleed screws, then you know the problem is something else.
Also, unless you have reason to believe someone has changed the braking system, the rear master cylinder, marked 'A' operates the front brakes and is connected to the upper vacuum booster. The front master cylinder marked 'B' operates the rear brakes via the lower booster. When bleeding the system it is advisable to do it with the engine running so that the vacuum boosters are operating.
Claude 23-10-18 07:11 PM
Yes, I agree, and did that first. When it did not produce the desired outcome (nothing came out of the bleeder screw), it suggested blockage somewhere. Of course, the fear is that the blockage is in the calipers - hard to remove and expensive to rebuild or the MC was on the way out.
So, in the absence of knowledge, I had to look at the brake system as a series of parts and work out which were the most likely to have failed. At the same time, some of those parts are hard to access and difficult to disassemble, with the risk that if, for example, a nut were to strip that could mean needing to buy and flare a new brake line with a new nut. For me each unexpected, sequential failure means cycling to the ferry, 45 minute ferry ride, walk to the car park, half an hour drive (or double if the motorway is jammed) to the brake store that permits me match up parts in the absence of a book listing parts for a 1970 Bristol 411, and then reverse this travel to get home... yesterday that meant leaving the house at 8:45 a.m. and arriving back home at 2 p.m. (I took advantage of the trip to town to do other shopping errands as well). I recite this because many owners will have similar challenges if they don't live near a qualified specialist but they don't want to wait months to sort a 15-minute repair.
If I use the brake MC as the pressure device, I (a) have no way of determining if it has failed or something else is bad and (b) there are some suggestions that I can damage it, pressing it to the floor as the piston goes into an area that could have decades of gunk that it never hits during normal use.
For what Americans call "shade-tree mechanics", the procedures are very different than repairs done by qualified mechanics in proper shops with a full inventory of tools and parts on hand. For a start, the car is not on a hoist but on stands where one must lie on one's back and slide in and out with a creeper. This means avoiding the areas where dirt falls in one's eyes (even wearing glasses that steam up) or where hands get cut when a frozen nut releases fast. Instead one selects access areas that are more accessible. It means looking for the parts that are easiest to remove without damage, or if damaged, easiest and least expensive to repair.
The problem facing shade-tree mechanics is that no one writes manuals for them. When the part is diagnosed, they can't ring up the dealer and have the correct part sent over because there is no dealer and there is no part number.
So, as I looked at the challenge facing me I saw that I wanted to avoid the delicate bits, like pistons or servos, and start with dumb bits like lines, hoses pipes and junctions. The tools one can buy to test these bits are expensive and made for shops that use them hundreds of times (and in my case, must come from overseas). However, the local hardware store does sell oil cans - the old fashioned devices that they use as the icon on the oil pressure gauge - for about NZ$12. They sell clear hose for $0.77 per metre. And I already had a brake line flare kit and some left over metal pipe and correct size nuts. The previous day I had purchased 5 litres of brake fluid for NZ$69, so I had a surplus of disposable fluid to test.
It took more time to set up the test than it did to run it, but it confirmed that the rubber hose was blocked. Next day, the brake repair shop kindly let me in the back where I went through racks of hoses and found the exact match for all of NZ$28 (to determine £ equivalent divide by 2 [£14]). It was marked H892 and the book said it was for a Hillman and a British Ford. Online they say it is for lots of British cars of the era, but no mention of Bristol.
The purpose of the subsequent documentation is to assist the next owner facing a similar problem. The task is to find easy ways to diagnose potential problems using common resources. While, for example, your suggestion of using the MC to test with the engine running does have the benefit of being a built-in tool with 1500 psi, for a shade tree mechanic it means doing the work outside, since running an engine in a tight garage is ill advised for health and safety reasons. That means potentially leaving the car outside on stands for days while one tries to isolate and repair the problem, or putting everything back together again to drive the car back into the garage and hope one has enough braking power to stop the car.
Forgive the length of this reply (editing takes more time and I do need to get back to work), but the point is to suggest that I am not alone in this challenge, and one of the great benefits of forums is that they permanently record shade-tree challenges and solutions. If each of us so documents, gradually a wealth of knowledge develops... knowledge such as knowing that a hose Bristol used was made by Girling for a Hillman, or that hoses commonly block if the car has sat for years and should be tested using a simple shade-tree-made tool.
peter dowdle 23-10-18 09:08 PM
I apologize for not having suggested a blocked brake hose. I have had this problem on my 365 GT4 . Both front and rear. What happens is that the master cylinder has plenty of pressure to force the fluid through to activate the brakes but the fluid wont return when the brakes are released causing the pads to stay on. The problem is one of swelling rubber on the inside of the rubber line. No amount of flushing will fix it.
Kevin H 23-10-18 11:54 PM
Thanks for the context Claude, it will help other readers understand why you took the approach that you did. It will be interesting to know the outcome when you have finished.
As an aside, did you receive the email I sent to you on Sunday?
In it I mentioned that if you take the calipers off the car, you might be able to get the pistons out without splitting the caliper by using compressed air. It's safer in terms of damaging the piston or the caliper bore, than trying to pry it out with a screwdriver. Although it's more fiddly replacing the seal in the caliper bore and putting the piston back in if you haven't split the caliper.
