-   -   Wanted: 407 Parts (https://www.bristolcars.info/forums/showthread.php?t=1538)
PaulusFryus 08-04-18 09:27 AM
Wanted: 407 Parts
Hello Everyone,
I'm looking for the following parts for my 407:
Water pump (313 V8)
Door check strap (drivers side)
Ignition coil & resistor
Any help would be gratefully received!
PF
Geoff Kingston 08-04-18 08:48 PM
From what I remember when I had my early 408 with the 313 engine the replacement water pump I got was the same as the later 318 engine.
MYTA21 09-04-18 05:51 AM
I got a new pump from one of the MOPAR people- possibly Pentastar Products, but you may find differences in the pulley dimension, or a union as I recall. Local garage fitted it OK anyway. On the coil etc, again MOPAR items, but check voltages. Standard car has one white porcelain resistor on the wiring board.
Thor 09-04-18 06:30 AM
Mancini Racing, in USA, are a helpful bunch.
Nick Challacombe 09-04-18 08:16 AM
407 Spares
I have found a water pump in my garage and a couple of coils and voltage regulator, no luck with the door strap.
PaulusFryus 09-04-18 12:14 PM
Thanks everybody; Nick would you be willing to part with these items? thanks again, PF
Nick Challacombe 04-05-18 08:40 AM
407 Parts
Many apologies, we have been moving house and everything has been upside down including getting on forum.
The answer is Yes.
Nick
PaulusFryus 21-05-18 02:54 PM
Hi Nick,
I really would like to buy the water pump for my 407. The bearing is getting noisier! How much do you want for it?
