401/403 lights
Can anyone help.
I am looking for a dashboard ignition light and rear number plate lights for my Bristol 401. Does anyone have any ideas where I may be able to locate the above items. George |
Hi George,
What are you looking for the bulbs , bulb holders or both. If the latter I might be able to help on the ignition light fitting if it is on my spares car, number plate light fitting now almost impossible to find ,bulb easy but far better to use a more modern fitting, led's well worth considering. Most of the original number plate lamps are now too far gone to be of much use and if not they are not much use unless you want to avoid the Rozzers! Geoff. |
In both cases I am actually looking for the unit itself.
George |
Is it rude for me to add to the shopping list?
I am in need of an interior bot light fitting - all I have is a flattened base. In the event of these being unavailable ,has the installation of a discrete LED fitting been done? Come to think of it ,is there an interior cabin light? |
401/403 lights
401/403 lights
Sorry "Boot" light .
| All times are GMT. The time now is 03:58 PM. |
