-   -   Wanted for my 403 restoration (1402 - reg NXT 655) (https://www.bristolcars.info/forums/showthread.php?t=1411)
mikebro 18-12-16 11:21 PM
Although I won't need these for some time, the following are missing from my otherwise fairly complete 403 and so far I have been unable to source:-
-both front roller blind mechanisms
-rear blind mechanism
-rear window aluminium finishing strip
-rear window wood fillet
Any help very much appreeciated
Best regards
Mike Brooks
BOC and BODA member
peterg 21-12-16 10:51 AM
I used very thin ply wood, cut it into strips, glued, wrapped and clamped it around the finishing strip until it filled the void. Rather fiddly for an amateur cutting it free style in the back garden but should be fairly easy for someone better prepared.
I have the remains (90%!) of the sheet in London if you need it/ some.
mikebro 21-12-16 12:13 PM
That looks a good solution to the wood fillet problem. Regarding the aluminium finisher strip which is also missing, can you confirm this is the same profile as the finisher round the driver and passenger doors?
Thanks for the offer of the ply, but I'm in NE Scotland so will source locally.
peterg 21-12-16 06:21 PM
I think it is but the car is away having a rebore, so I can't check
jasa 22-12-16 04:20 PM
Rear window finisher
HI Mike
If you haven't managed to find one yet , I think I may have one in the depths of my loft. I may not be able to look till after Christmas but let me know if it's still a requirement
Best
Mike
mikebro 16-02-17 02:27 PM
Mike
Yes please if you can find it! Let me know what you want for it.
Best regards
Mike
Originally Posted by jasa (Post 8697)
HI Mike
Best
Mike
