Bristol Fighter
Can anyone help with the correct gas strut dimensions and Nm settings for the Fighters, Bonnet, Doors and hatch?.
Ken, if you can't find this information, a good gas strut (gas spring) manufacturers should be able to tell you how to take the measurements they require to make new struts for you. I take it the original struts don't have any markings on them? They often have a little label with the Nm setting.
I did this some time ago for a V8 Aston bonnet, but it was in Australia so not much point in mentioning the company who made them for me. This is what they wanted from me; Length of your gas strut? _____mm (Measure from the middle of the end to the middle of the other end when fully open) Diameter of your gas strut shaft? _____mm (Measure across the shaft that goes in and out) Strut ends? ______ (Plastic, Metal, Ball Cups, Clevis & Pin) The weight of the door at the anchor points of the struts. (Use bathroom scales and a stick, place the stick at the anchor point of the door in the open position) |
Hi Kevin, thanks for your reply to my post, I'll have to try and sneak the wife's scales out of the bathroom without her seeing me, but as I haven't had any SAS training that could be a difficult task.
Many thanks, Ken |
| All times are GMT. The time now is 06:33 PM. |
