-   -   401 Exhaust System (https://www.bristolcars.info/forums/showthread.php?t=1244)
zbigmak 17-08-15 05:50 AM
401 Exhaust System
Can anyone suggest a supplier for an exhaust system for the above car - either in the UK or Europe
405dh 17-08-15 07:35 AM
401 exhaust
1. Bristol Cars will almost certainly be able to supply.
2. For stainless steel systems I can thoroughly recommend JP Exhausts of Macclesfield. They will have the pattern to work from or by prior appointment they will make and fit a system to your car in a day. Turn up at 8.30 am and drive away late afternoon. They supply a lot to the trade but will also deal direct with owners.
Chris.
Stefan 17-08-15 08:39 AM
Stainless exhausts
If you aren't able to get to Bristol cars, Longlife exhausts will make you a custom built stainless exhaust with a lifetime guarantee. They have various branches - the one near Bristol did a good job on my 400. You can specify a larger diameter tailpipe, maybe a good idea if your engine output has been raised.
