Window circuit breakers
Could someone tell me where the window circuit breakers are on a 1972 411?
Thank you. |
"circuit breakers" ?
If you mean relays, there aren't any. They are just wired straight to the switches! Bristol weren't big on relays ;-) I ended up re-wiring mine because the original wiring was quite thin and the bullet connectors were in poor condition. |
The wiring diagram I am looking at has four circuit breakers for the windows. There is an up and down for both the right and left side windows. I couldn't find anything around the fuse box area. Perhaps they are in the doors next to the motors. I didn't want to pull a door panel if not necessary.
Thank you. |
No circuit breakers on the 409 I have, but two fuses on the forward vertical face of the A pillar RHS. Yes, the wiring is none too good with its bullet connectors. Mike O
There are however no "circuit breakers". Are you sure you are not mistaking the switches for circuit breakers? Or do you call a switch a "circuit breaker"? |
| All times are GMT. The time now is 03:02 AM. |
