-   -   409 SS trim (https://www.bristolcars.info/forums/showthread.php?t=1206)
Anne 05-05-15 01:47 AM
409 SS trim
I need help in removing the side trim pieces on the fenders and doors, prior to painting.
What is the trick?
Anne
Anne 05-05-15 04:11 PM
409 SS trim
How are the stainless steel trim pieces taken off the door and fenders?
Anne
David Olivant 05-05-15 05:28 PM
409 stainless side trim
Start at one end, slip a piece of HDPE under the end. Use a
David broad blade screwdriver and gentle lever off at first clip. Continue along clip by clip.
You can buy clip removal tools which are plastic
Anne 05-05-15 09:39 PM
Thank you,
Have tried a thin bladed knife to try and lift but ..nothing so far.
What is HDPE ?
Anne
Kevin H 05-05-15 11:12 PM
HDPE is High Density Polythene
Anne 06-05-15 02:03 AM
Ok Thanks...will try again,
Anne
Kevin H 06-05-15 04:41 AM
Anne, once you do get the trim off, would you please post a photo or two on here for the benefit of others who may be faced with the same task.
Being able to see what you are dealing with is often better than a description.
MYTA21 06-05-15 08:04 PM
I think you'll small nuts on the inside, possibly covered in a rubber seal coating. I found that was how the rear wing strips were fastened.
Mike O
Anne 09-05-15 09:22 PM
Ok the mouldings are off ! The first one took some doing and then once I figured it out the rest were a breeze.
Used a small penknife and work from under the moulding and pry upwards.
Hope the upload on this site works...No I see that I can't upload pictures.
Anne
Anne 09-05-15 09:29 PM
Ok..tried again to add pictures....easier to take the mouldings off
Anne
