-   For Sale - Cars, Parts & Automobilia (Bristol related only) (https://www.bristolcars.info/forums/forumdisplay.php?f=19)
-   -   401 on ebay! (https://www.bristolcars.info/forums/showthread.php?t=1184)
David.H 07-03-15 10:58 AM
401 on ebay!
There is a 401 on US ebay, in Los Angeles, with a 6 cyl unnamed engine, but with a Bristol block & some engine bits. & days to go! Item 221707259348.
8 brave bidders so far!
John Simmons 09-03-15 04:13 AM
The engine is a Ford 6. That engine came in either 144, 170, or 200 CID. The intake manifold was integral to the Cyl Head and had a 1v carburetor. They have welded up a horrible modification to the original manifold for the SU carburetors, with 3 right angles in the flow path, and it looks like the only connections to the original manifold are at the ends.
Geoff Kingston 09-03-15 04:00 PM
John,
Is this Ford engine the same type fitted to the late 50's early 60's english Ford Zodiac and used by AC.
The car itself has been through a few dealers over a period of around a year, it is a job to work out from the photograps how sound the main chassis is and i notice also it has a KPH speedometer despite being RHD, might have an interesting history, don't like the look of the cut away bumper especially if it was done to overcome cooling issues.
A few other interesting bits came up using Bristol 401 as a search item so well worth a look.
Kevin H 11-03-15 05:21 AM
A couple of people tried to post to this thread by email and their emails came to me (webmaster) so I will post them here;
One was a link to the dealer's own website, which gives an indication of the price sought ($26,000). Seems high considering the car needs total rebuild and de-modification, and no doubt some hard to source engine parts. Assuming the block is sound and the crank is still usable.
1951 Bristol 401 Coupe
The other was this comment;
"Very interesting. Apparently it is chassis 401/909, body 401/2/308 & the block with it is 85C/1814
Not for the faint hearted! Not sure I am brave enough!"
David.H 11-03-15 08:46 AM
A quick look at the website makes it look as if they specialise in "Sheds". Some very tired & rusty money-pits there.
