6 cyl oil filter
Hi,
As a replacement for the original filter in my Arnolt 3086 I use a Mann paper element with the correct oil flow direction. It is easily found by its Mercedes-Benz part number MB 000 184 4325 or A0001 180 0009. The Mann no is H720 It has the correct size but you need to make adaptor plates at each end to ensure the oil flow and its position. Best regards Kenneth |
6 cylinder oil filter
Dear Kenneth
I was the originator of the thread seeking oil filter solutions to the need for a correct oil path filter arrangement and I did finally secure exactly the same adapter as you have so kindly photographed and I can now claim to have found the detail that I was originally seeking. Thank you so much for your help. Kind regards Marcus |
| All times are GMT. The time now is 08:50 AM. |
