Radiator dimensions
Hello
I'm a new Bristol owner embarking on the restoration of a 408. I will post pictures and info as soon as I start, but I have a pressing issue with the radiator. I am ordering a number of parts from the US and am having a custom radiator fabricated. The car did not come with a radiator at all, and I am unfortunately far from any other Bristol... Would anyone be kind enough to post dimensions of their radiator? I believe there are only few differences between all the V8 models . Also if you have pictures of refabricated radiators, that would be significant help. Thanks |
I have an old 408 radiator and fan assembly
V8 Radiator dimensions
6 Attachment(s)
Here are the dimensions from a 411 radiator:
W 71cm or 28 inches H 51.5cm or 20.25 inches D 54mm or 2 1/8th inches I hope the images help. Good luck with your restoration. Greg |
Many thanks. This is incredibly useful.
But the 408 radiator is a lot different to the 411
Well the car is an odd one. Started its life as a 408, but now with a 410 front end. Do you know if the 411 radiator will go into a 410 nose?
Probably - sounds an interesting car , any pictures ?
If it has been modified like you say then maybe the best thing to do is to measure it up yourself. Make it 2-3 cm smaller in height and width, so you can have brackets made locally and fitted. As you live in a hot country I would make the radiator thicker than the usual ones fitted to Bristol, with 2 electric fans fitted in front.
| All times are GMT. The time now is 04:20 AM. |
