Pedal Rubbers Holdtite
Has any kind person a pedal rubber for an early V8 ?
Thank you Nick |
Rubber covering for brake pedal
It is not that uncommon for small manufacturers, like Bristol, chose a pedal assembly supplied to other manufacturers, and could possibly be the same one used by Jaguar, for instance. I would take measurements and shop around. The chances of finding new old stock are slim at best, but who knows?
Think I have one knocking about - will let you know
Thanks Greg, They are the wrong size by a long way those are no 16 the Bristol has no 64I have been all through eBay ands there are about 12 pairs but none are right.
Thanks again, Nick |
Tried Jaguar but no size matches up. I thought the ones on ebay that Greg mentioned might do but they are huge, maybe a bus one. They are quite often on eBay I have noticed. Thanks for trying.
Bigger the better :-) just bond a piece of metal the same size as the rubber on eBay to your pedal, then fit the rubber to it !!
Alternatively , I'll dig the right one out |
| All times are GMT. The time now is 07:13 AM. |
