It will be interesting to see how much of a real improvement the Sniper 2 offers. Do let us know if you get one, and what it's like. Although my first one failed (dead ECU after an hour or so's total running time from first start) I get no interference issues with my Sniper, for instance, and the basic connections are genuinely easy to follow. Possibly the major new thing is easier connection to their electronic distributor?
I haven't got to that bit on mine yet - am still using the stock distributor albeit with Pertronix kit installed. I haven't even mapped the advance curve yet.....hmm.....perhaps I should stop typing, put my laptop away and get my timing light out.......... |
I think you definitely should!
I'm not sure about the 411, but the Poly engine in the early V8s has the distributor at the rear of the block so I don't think interference would be a big issue. Ford engines with the distributor right next to the ECU seemed to be the worst offenders. The big issue for me was the number of reports of failed ECU on the original Sniper. I very much hope version 2 is more rugged. V2 also supposedly has improved throttle geometry. The main reason I am considering a Sniper is that fitting overdrive brings the engine speed so low at motorway cruising speeds that a standard distributor doesn't have the timing range to cope. Also the Weiand inlet manifold that I have presents mixture issues at low RPM that are hard to accommodate with a standard carb and distributor. These are both marginal issues but adding a Holley Hyperspark controlled by the Sniper should bring everything into line. Add a decent tubular manifold with ceramic coating and I very much hope to have an original engine and nearly original transmission with the drivability and economy of much more recent cars. |
Re using a Holley Hyperspark distributor: the Sniper 1 can drive the Hyperspark but I can't remember how easy the connections are. Or you can lock out the mechanical advance on the stock distributor and get the Sniper to run that. In both cases you tell it to run the distributor in the hand-held terminal's base settings menu.
Re throttle bracket geometry, Holley sell a small Mopar/Chrysler extension bracket, (Hly-20-7) which I used, to get the geometry right. Apparently Torqueflites use rods & bellcranks for managing the upshifts and kickdown and the added width of the Sniper vs a carb, plus a bit more still from the adaptor bracket meant that it seemed best to get a new top rod (the cranked one from the throttle bracket to the top bell-crank) made. This was a mirror image of the original ie the bend was in the opposite direction, but it was the same length & number of threads. It took a bit of internet research followed by a bit of playing about to get the adjustment right. Probably easier if you remember to count the visible threads on the stock setup first, which of course I forgot to do!....d'oh.... Here's a list of all the parts I used - hope it helps: Holley: Sniper Classic gold (550-516), Drop-in Returnless Fuel Module with 255 lph pump and Hydra-mat (12-131), throttle lever extension for Chrysler (20-7); Weiand: sealing plate 9006 for spread-bore manifold-to-square bore carb/Sniper; Felpro: intake/lifter valley pan with blocked exhaust heat riser 1214; Merlin Motorsport: 1/8 NPT Smiths temperature gauge sender CB-TS-18; Bespoke: top throttle rod in mirror image of original Bespoke: exhaust diverter housing on UK driver's side between exhaust manifold and downpipe Small assortment of -6AN (9/16 UNF) and ¼ NPT blanking plugs and hose barbs; ¼ NPT-to-1/4 BSP adaptor if you use existing fuel feed pipe which came from the main/reserve valve; 2m of R9 fuel hose; 6 good quality efi fuel hose clips; can of Chrysler Orange engine paint; assorted gaskets; lots of tea. Then more tea. Total cost was c.£2k. |
Really useful information, thank you.
I have done a bit of reading about it and there seems to be general agreement that it's a good idea to have a post pump filter even if you are using a Hydramat. I'm torn as to whether to go for the Hydramat. It looks brilliant if making a tank from scratch but since the Bristol tank has baffles and a sump I wonder how much advantage it gives. I think the size you have chosen along with how often the car is used will give a good few years before it clogs but I'm more inclined to let some of the small particles go through the pump and collect in a 10 micron post pump filter that can more easily be replaced. By no means a criticism of your choice. I may well decide on a Hydramat but haven't made my mind up yet. My shopping list currently looks like this: Sniper 2 550-510 3xx $1300 Hyperspark distributor 565-344 $400 Fuel pump 12-169 $490 Coil 556-153 $45 Filter 162-554 $120 Filter brackets 162-574 $45 Total $2400 These are not confirmed choices that will definitely work together, just the best I can do for now after a bit of on line research. I am waiting to see how well the overdrive gearbox conversion works. If it's a success I think the Sniper will follow soon after. |
I used the Hydramat just to be on the safe side, as the stock tank baffles weren't designed for the needs of an efi electric pump. Haven't (yet!) used a post-pump filter, other than the one in the stock position near the Sniper (to disguise the conversion) which I forgot to put on the 'stuff used' list. It's a Vauxhall part and I can get the part number if you need it. I'm assuming in all this that David C is in the UK, btw.
My 411/3 has a 383 B block, so the distributor is UK driver's side, front, at 45*. I think the small block ones are like a traditional small block Chevy, in the middle, vertical, at back of intake manifold? What transmission are you going to use David? A 4 speed o/d Chrysler one will bolt to directly to a 318/340/360 block I think, but an old 383 like mine needs an adaptor. In view of availability, need for an adaptor anyway, trans case size etc if I do get round to a trans swap then a mildly-built GM200-4R looks sensible.............(am a long way from deciding, but in any event I await the torrent of abuse from purists......) |
David - if the Weiand inlet manifold causes too many issues am happy to look after it for a while......
I am indeed in the UK.
I have gone for an A400 42RH transmission. It's a fairly straightforward bolt on replacement. Needs different flex plate and lower cover for torque converter. Also a small ear had to be removed from the block to get the starter motor to fit. 46RH are a bit easier to find and are a bit stronger. Most of the work is in modifying the gearbox crossmember and transmission tunnel. Article to follow... The Poly engine in the 409 and 410 is internally balanced so works with the lock up torque converter without any modification. I think I previously saw that the 383 is also internally balanced but that would need to be confirmed. If so it should be fairly straightforward to bolt to a 46RH with a suitable adapter kit. As long as the engineering is done well I don't see a problem with a GM unit. Wilcap make a suitable adapter. I think you will need an electronic adapter if the GM 'box is electronic. It would be good to hear from others on the forum whether they would welcome an extra gear and better fuel economy or would be put off by non original gearbox. Also, once it's non original does it make any difference whether it's Mopar - developed from the original - or from another manufacturer. |
More on the Weiand inlet manifold on my 410-
For those who are interested or just need help to go to sleep there is plenty of reading on offer regarding inlet manifold arrangements, specifically square bore and spread bore. I believe 410 and 411 original manifolds were spread bore. The Weiand 7403 manifold is divided square bore. This means the Sniper should bolt straight up. The question is whether I will get much benefit as square bore is better at higher revs but may lose torque at lower. The 42RH gearbox has a lower first gear which may offset this. I'm hoping that combined with decent tubular manifolds the improved breathing will give further improvement to fuel economy. If it doesn't work out, Andrew is at the front of the queue for parts to make a fire breathing monster. |
I was just reading through some earlier posts when I came upon Dezelsky's from June, when he was touring in Italy with his 411/4. I'd completely missed the photo he attached, and just had a look. Man, that is a pretty car! Perfect angle for the picture, and the combo of the wheels and colour really suit it.
Life is too busy, but I have acquired a Sniper kit to put on the 318 Poly in my 409. I feel very sure that at the very least a transmission with a lock-up torque converter is required. A GM 6L80 would need an adapter but there are controllers for it. I've thought about a 42RH as I had a Dodge Dakota for many years with the Magnum 318 and 42RH (I think). But if you're going to the trouble of changing the trans and have the electronic outputs from a Sniper, it's relatively easy to install 6 or even 8 gears. I have no idea whether these fit under the Bristol floor without modification.
Re David C's manifold intake manifold points, the Weiand design has got to be more modern (or perhaps less aged...) than the original mopar one? And I can't think why efi would need the help with fuel-atomisation of small primary bores. Am happy to be educated though if anyone knows different! Sniper is wet flow so surely avoiding the puddling of fuel in the intake matters more? The divided plenum should work ok - mine runs fine with a stock intake.
Re the transmission: I want my 411/3 to be easily(ish) returnable to stock in the future (dunno why, it just seemed important!) so part of the GM200-4R appeal is it's relatively small size. It's controlled via throttle-valve cable (like a TH700-R4) so no additional electronics to worry about - apart from TC lock-up. GM transmissions run by the ecu startd with the 4L60E and it's successors. Great trans, had one in my '95 Corvette. Additionally the 200's got a deep first gear and a lo-o-o-ong top gear. And thank you for not shouting at me for the idea of a foreign trans.....If I could find a separate conventional overdrive that fitted (not a Gear Vendors type) that would take the 383 torque then that would appeal too. Anyone got any thoughts? You can all wake up now...... |
I should really have said that the Weiand is a divided single plane whereas the original is dual plane. Supposedly the longer tracts in the dual plane allow the mixture to slow further and give a more dense charge at lower RPM providing higher torque.
Looking at the original manifold, one half turns through a right angle almost immediately on entering the manifold so common sense suggests more puddling on one side than the other. Since the Sniper only uses an O2 sensor in one of the downpipes I struggle to see how it can get the mixture just right in both banks. Hence I decided on a symmetrical manifold. If reading this gives the illusion that I know what I'm talking about, please don't be fooled. I very much welcome input from anyone who can see through my waffle and tell me where I'm going wrong. |
Weeelll........I actually rang Holley tech and asked them about this before I bought mine. The Sniper has 4 x 100lb/hr injectors, one in each of the 4 barrels in the throttle body. 1 x O2 sensor in one down pipe, which tells the ecu what fuel to provide. The ecu commands all 4 injectors equally and at once. So unless there is a noticeable difference in the fuel distribution to each bank (eg engine v badly worn) then each bank, and each cylinder, gets pretty much the same fuel. I used an adaptor/spacer plate, which was open with no divider, so all cylinders can draw equally-ish.
That's my understanding, and all the plugs now look roughly the same colour - a nice light tan, rather than the thick soot they had beforehand. |
I think I'm in danger of over thinking it here. The important thing is that you have a much improved system that is working well for a reasonable outlay.
With any luck a few more of us will get EFI fitted and be able to report back and fine tune what is required for those who follow. Thanks again for sharing ! |
Well over thinking is better than no thinking, which is the hole I sometimes fall into!
I just had a look at some forums, including Holley's 'Sniper efi' forum. The administrator and senior members (ie the ones who know the most I reckon) generally seem to think that a dual plane intake is fine with a Sniper. My own experience supports that.
I'm no expert, and I'm a VERY long way from knowing a zillionth of what a professional mechanic/engineer knows, but I firmly belive that a successful Sniper installation needs to be in a car with properly matched engine parts on an engine in reasonably good fettle with a good battery and charging system. It won't fix basic errors in matching cam and heads, for instance. Then just follow Holley's comprehensive instructions, particularly about electrical connections, and you should be ok. |
Fuel consumption update
Howdy y'all. Hope this update is of interest.
On a recent 140 mile round trip on single-carriageway A & B roads, 18-20*c, not exceeding 65 mph, mostly at 50-60mph, but several roundabouts and junctions to accelerate away from (gently, letting the torque do the work), driving on the gently side of normally (with no hyper-miling tricks) and measuring from a hot start I got 19 mpg. From a 383! Driveability absolutely perfect. |
Brilliant! Thank you for the update.
That does seem like a good MPG figure. Thank you for this information. I'm hoping to get a Sniper onto my 409, and also a gearbox with lock-up torque converter. With the smaller engine I would hope to be into the 20s on MPG.
At first it did seem too good to be true, but I double-checked my sums and actually erred on the side of caution!
Thor, I'm sure that with a smaller engine, o/d transmission and a lock-up tc you'll beat me easily - assuming your engine is in stock/mild state of tune. On a 40 mile drive at 60-70mph, hot start, I once got 31mpg from my o/d auto '95 Corvette, which had a diff ratio of c.3.00:1 and did 2200rpm at 80mph. |
Andrew is getting 25MPG on a run and Dick used to get a bit better on a continental trip in the same car. 410 with overdrive, Edelbrock carb and standard distributor.
It wouldn't be too much of a reach to hope for 30MPG or more if driven carefully with a Sniper EFI and Hyperspark distributor. I'm still waiting to get my car back with overdrive. If that goes as well as hoped I will fit Sniper, Hyperspark and SLJ headers. Very much hoping to report with real world figures early next year. |
They're all very good figures, especially for 50+ year old cars with (by modern standards) poor aerodynamics.
If only we could help DWomby with his dismal consumption! If I recall correctly David struggles to get into double figures with a 360 cid engine? Makes my own tribulations seem small. I looked up the cam specs of his Mopar Performance 4452761 and they don't seem too outlandish. So wrong timing/timing curve? Vacuum advance missing/not working? Cam incorrectly installed? Carb leak? Other leak? Fuel evaporating? Engine fault? Over-rich carb? Blocked air filter? |
I expect to start reassembly in another week or two when temperatures and humidity here have made working in the garage possible. I hope to get her back on the road before Christmas and the fuel consumption/tuning issue will no doubt need addressing then and I'll welcome all help! David |
As everything beds down I'm finding 25 mpg relatively easily achievable and a nearer 30 on long runs driven sensibly.
I do however enjoy making full use of kickdown when running around locally - it's difficult to resist - and then I'm back in the high teens. |
These are great results. Thank you for sharing. All the more reason for us to enjoy our cars!
A bit more reading on Mopar forums about Sniper upgrades has led me off on a bit of a tangent. Changing to EFI requires a fuel pump that can draw up to 20 Amps. Air conditioning can add about another 15 Amps.
These two upgrades alone can double the original current draw. The easy fix is to upgrade to a newer high output one wire alternator and do away with the original external voltage regulator. This is great but leaves the ammeter in circuit, wired with cable which isn't adequate for the new load and now a fire risk. Maybe the best solution is to do away with the ammeter and find a period voltmeter to replace it. Another option if keeping the original charging system would be to fit LED headlamps and wire the air conditioning to disable the heated rear screen when in operation. |
Interesting point DavidC makes, so I checked my own car. My '73 411/3 has a voltmeter, albeit a slow-reacting one. As a precaution I'd renewed the separate solid-state regulator at the time I fitted the Sniper. Alternator looks original-ish and there's no sign of an upgrade or replacement in the history file.
I checked the charging with my voltmeter, and with fans on (and electric fuel pump obviously) it charges at 12.75v (shows just over 13v on the dash gauge) and 12.25v with the headlights on main beam, as well as the fans. Normal running shows c.15v on the dash gauge, which reads a bit high in relation to my multi-meter. Exec summary: it seems to work. Referring to David C's earlier post about intake manifolds I experimented by trying my car without the (Holley-reccomended) divider-less Wieand sealer plate between the stock cast-iron spreadbore divided manifold and the square bore Sniper. I used a gasket with a divider strip. It ran ok at first but soon developed an air-leak that I couldn't cure so I went back to the original setup of open sealer plate with a gasket above & below, and it's running fine again. Whew.... |
Update after c.18 months with Sniper
Thought you might be interested in an update after 18 months or so.
The car still has the original Torqueflite 3 speed auto transmission and original back axle. With the original carb I got 13-14 mpg imperial on a run and about 11-12 mpg running around locally with 10-20 mile drives. Driveability left a lot to be desired and starting under most circumstances was poor. With the Sniper I get 15-18 mpg on a run (absolute best of 19mpg at no more than 60mph and no harsh acceleration) and 13-15 mpg running around, all imperial. Drivability and starting are greatly improved on top of the 10-15% fuel consumption improvement. It's all based on the Sniper's self-learning, with no manual tuning done. The original ECU failed after about an hour of running, but Holley accepted liability immediately and I got a free replacement from Summit which has been fine. I've had a couple of instances of a spit-back through the throttle body while pulling away during warm-up. This was traced to tbi mounting bolts loosening up for some reason, presumably causing a slight air/vacuum leak. I use the recommended sealing plate between the square-bore throttle body base and the stock spread-bore intake manifold. Have tried it without it, but got an air leak. Overall I'm very pleased. Would I do it all again? Yes, in a heartbeat. |
Thanks for the update. Tempting.
David |
Very pleased to hear all is still well. I have been keeping an eye on the internet for tales of woe about the updated Sniper and have seen few if any.
My installation of overdrive gearbox on the 410 has dragged on for various reasons but I hope to have it back on the road in the next week or so. If all goes well then Sniper and Hyperspark will be next. |
I forgot to say in the last post that the fuel pump is a bit noisy, too. I used a Holley 12-131 returnless drop-in fuel module, which has a 255 lph in-tank pump. I added a Hydra-Mat, too, in lieu of a reservoir/swirlpot. All seems to work very well.
Do you think it would be a good plan to put some neoprene or similar under the fuel tank and also between the straps and the tank?
Perhaps a bit of Dynamat on top of the tank to damp any ringing. |
Hmmm......I must say I hadn't considered anything between straps and tank, or below tank, but I have put as much sound deadening as will fit between the tank front and seat back, and above tank.
Next time you have access I suggest you place a hand on the top of the tank with the pump running. If you notice any lowering of noise level then one or two pieces of Dynamat or similar about 6" squareish may well help. If you can feel the pump vibration then decoupling the tank from the bodywork with something resilient is worth a go.
Sorry David C, for some reason (ineptitude?) have only just seen this.
Sounds like sound advice. |
I'm pleased to report that my 410 is now sporting a Sniper 2 fuel injection unit with hyperspark distributor. First impressions very good other than fairly loud injector tick. A returnless pump went in the tank without too much trouble. I re-jigged the wiring loom to tidy it up and moved the pump relay to the fuse board. The throttle linkage required a fair bit of measuring and a bit of fabrication but otherwise it was surprisingly straightforward.
David, thanks the update.
I hope it works out for you as well as it has done for me. Mine isn't perfect, I occasionally get a stall when pulling away from stop during warm-up if I open the throttle quickly, but that's about it. I've left the programming completely alone ie it's all self-learnt. Maybe a few goes at more throttle from standstill while it warms up will nudge it to learn more in that particular TPS/MAP/CTS/oxygen sensor combination? Or maybe I've got an air or exhaust leak somewhere? Must admit I've never bothered with any data-logging with it. Also my (Holley in-tank) fuel pump is noisy, even with a full tank. But at least I know it's working! |
I think your pulling away issue has been fixed on the Mk 2. As both butterflies open together rather than one after the other with the carburettor I have to be quite gentle on take off or I get thrown back in my seat with quite a jolt. I haven't noticed huge pump noise but it may be due to all the other noises. There is quite a loud injector tick and I think noise from pulsing in the fuel filter mounted on the inner wing. More fettling and investigation required but it's a very promising start.
I will try to get up to one of the East Anglia meetings so that we can compare notes. |
Update:
I mentioned that I occasionally got a pulling-away stall when the engine was cold. This developed into frequent cold stalling, including on the over-run when slowing for a stop, plus increasingly hard cold starting and occasionally dodgy hot starting. I had a dig around on the Holley Sniper forum and it seems I'm not the only one with this type of problem. Suggestions were to check the Coolant Temperature Sensor reading vs the Manifold Air Temperature via the supplied HandHeld screen, as the OEM CTS have, in some cases, been shown to read high on a cold engine and low on a hot engine. On a cold engine the IAT read 55*f but the CTS read 71*f.....too much of a discrepancy. It's a common sensor type (Standard Motor Products TX3 or equivalent) and I had a spare which was known to be good. I swapped them over and all was good, with now only a 1*f difference. |
Good evening all, my first post on the forum. I’m in the process of acquiring a Beaufighter and in my research came across a PWM fuel pump controller, VaporWorks, which runs the pump depending on demand so should be much quieter, just a thought.
| All times are GMT. The time now is 12:03 PM. |
