On mine when I swapped from SU to Facet I checked the specs of the carb to make sure I knew what it wanted in terms of pressure and flow. The silver top pump seemed most appropriate for my small block but a red top is probably what you need.
I bought the kit which includes new bobbins etc and a selection of springs from Facet so you can alter the pressure of the pump by unscrewing the bottom of the pump and swapping the spring over. I had two goes at mounting it until I found a spot where it couldn't vibrate against anything. On mine it's very quiet (inaudible when running) and I'm happy with it. I didn't use a regulator and all seems fine. On previous cars (not Bristols ) I've used them and mounted them in all sorts of places - so I wouldn't worry too much about whether it's below the bottom of the tank or not - they seem to cope. Hope this is of some use! |
David |
David |
I quite like the idea of an auxiliary low volume electric pump to prime a system with main mechanical pump. It would be easy to control with brief timer as used with diesel injectors. That said it seems to be a fix for an unlikely problem. I understand the concern of pump running and leaking fuel with engine off and ignition on but there are other safety issues I would deal with first. The most notable is lack of headrests in the early V8s but thanks to a suggestion from Giles Parsons I hope to be sorting this soon with some from an MGB.
David |
Still at the planning stage. I think a steel frame will need to be fabricated to transfer the load to the wooden sides. I believe Giles had the work done by a trimmer in Cornwall. I contacted him by email but had the reply that he couldn't remember the specifics of that conversion.
Knowing that the job has been done successfully I plan to get some second hand MGB seats and give it a go. |
I don't see the need for a timer, unless you want it be fully automated with the ignition switch. You could just use a momentary on-off switch, which you press for a few seconds to fill the carburettor before depressing the accelerator pedal and engaging the starter motor, (ideally a reduction gear starter motor). It may only be required when starting from cold when the car hadn't been used for a long time. |
although I hesitate to add points of complication/potential failure. David |
When my Mallory order got cancelled, I quickly grabbed a Carter P4070 and installed that. I have a 100 micron filter between the tank and the pump. After the pump I have a Mallory deadhead regulator holding the fuel pressure to 5PSI followed by a NAPA Gold filter before the carb.. The new pump provides rock steady 5PSI through the regulator and everything seems to be working fine. The pump comes with a mounting bracket and rubber isolators to reduce pump vibration passing to the bracket. In addition, I mounted the bracket to the car using rubber 'bobbin' type mounts to further isolate it. The pump seems loud before firing up and can be heard above the idle but once above idle, the sound is lost.
I may try a mechanical pump as a project for next winter but for now the car is for driving although it needs some tuning. David |
Good news. With me there was also an element (for a while) post installation of consciously trying to see if I could hear it which doesn't help!
| All times are GMT. The time now is 11:24 PM. |
