Sticking fuel gauge needle...
Old 07-09-09, 11:48 PM
browning l browning l is offline
Default Sticking fuel gauge needle...
What would be a typical reason for a fuel gauge needle to stick at the left side? Happens occasionally, then the next time one starts the engine, it does not do it.
Old 08-09-09, 02:49 PM
Sam410 Sam410 is offline
I don't know, but mine does it sometimes too. I tend to calculate the urgency of finding petrol by the odometer rather than the fuel gauge.
Old 08-09-09, 03:18 PM
ex member
I know nothing about the late cars but if they have a float in the
tank operating a potentiometer then it is probable causing the
problem. They tend to stick, especially of the car it left standing
for a time. The best thing is to remove it from the tank and waggle
it up and down to remove any sticktion. Clean out the pot bearings
if necessary.
Ash
Old 08-09-09, 05:20 PM
First, easy item to check are the electrical connections and ground
to the sender. My Alfa gauge wiggles and this will be done soon!
Old 08-09-09, 08:55 PM
Unfortunately to do that on the later cars you have to remove the rear window first I think.
