411 s3 parking brake callipers
Old 25-05-26, 04:35 AM
Ed.bass416 Ed.bass416 is offline
Default 411 s3 parking brake callipers
Hi Forum,
I am renovating the rear brake callipers and came across an issue. The little auto adjust nut on the parking brake has been replaced by a fixed bolt. Does anyone know where I can find a replacement. It’s the nut with the clicks that turns against the spring to tighten the cable… it’s item 25 in the picture.
Thank you
Old 25-05-26, 10:26 AM
Try Martin Robey or Jensen Service Ltd. After that vintage Aston Martin specialists.
Old 26-05-26, 04:34 AM
Ed,
Here's a full parts list for the Girling 12/13 HP brake caliper and handbrake assembly:
https://www.bristolcars.info/forums/...&catid=7&id=58
It's called the Adjuster Nut, part # 64326238 and appears to be common with all handbrakes across numerous contemporary car marques, which might make it easier to find.
Old 26-05-26, 04:44 PM
I had the same problem. Got mine from CBCPC.
Thomas
Old 29-05-26, 10:16 PM
Default Thankyou
Thanks guys, adjuster nut sorted. I’m just missing the little clutch ring and the dust cover - anyone come across these on their travels?
Old 31-05-26, 02:57 AM
Hi Ed,
Pray tell where you obtained the adjuster nut
It may help others in the future.
Old 04-06-26, 01:33 PM
Default Adjuster Nut
Hi,
Graeme Payne
Classic Bristol Car Parts Company Limited
He’s a great help and was able provide other difficult to find parts like the accelerator mechanism bushings.
I should have known to go to Graeme first!
Thanks for your help
Ed
411s3 brakes
