411 Door Seal
Old 19-06-25, 02:57 PM
Default 411 Door Seal
I am after a door seal for a Mark 1 411 that would fit around the window surround on both doors. When I purchased the car they were not fitted but I am sure there should be one to make a good seal from draughts and wind noise?
Would anyone know where I could get this and if they come premade to fit or are a buy a length and cut to size?
Any help would be greatfully recieved
martin
Old 22-06-25, 07:02 AM
Your best bet is to talk to Graeme Payne at https://www.classicbristolcarpartscompany.co.uk/
You need an extruded rubber profile which is not dissimilar to others on the market but the others aren’t quite right. Bought as a long length and cut to suit.
I found it also helped (on a 410) to add a plush seal, trapped behind the headlining fixings, that bore gently on the inside of the chrome frame.
It’s worth doing the rear windows as well, they use a different profile. Apart from anything else a new seal makes the over centre catches much more positive.
