1974 BRISTOL 411 SERIES 4 - just acquired
  #21 (permalink)
Old 24-05-24, 06:02 AM
Hello Hess,
thank you for going throu the trouble of writing down the part numbers. I have a question about the front hub bearing: The bearing LM48548/LM48510 is the outer or inner bearing? Do you also know the dimensions of the corresponding bearing?
Kind regards
Thomas
Originally Posted by hesketh786 View Post
Dear Thomas,
Yes of course, I have bought exactly the same as the originals on the car.
FRONT AXEL BEARINGS - 48548/48510 Dunlop Tapered Roller Bearing 34.925x65.088x18.034mm
FRONT AXEL OIL SEALS - 27618750D
(I couldn't find these online so bought a pair of them from Spencer Lane Jones, will share sizes when they arrive)
REAR AXEL BEARINGS - 2735X Bearing 60.72x73.03x19.05
(Again I couldn't find these online so bought a pair of them from Spencer Lane Jones, will share sizes when they arrive)
Other parts you may require for the rear axel hub if overhaulling :
BRG53 Halfshaft grease seal: £8.12 each
- Outer seal houses in pressed steel housing
BRG110 halfshaft oil seal: £14.59 each
- Inner seal, housed in end of axle casing
AXL140 grease seal housing: £37.54 each
- Housing for BRG53, sealing face often found to be warped and a source of leaks
GKT123 gasket, grease seal housing: £3.17 each
Kind regards,
Hass
  #22 (permalink)
Old 26-05-24, 09:20 AM
Morning H
Car looking great and coming together really quickly!
You should do the Southport Sprint in it and we can have a head to head!
Spurred on by you I'll update my rambling thread!
All the best
  #23 (permalink)
Old 30-05-24, 06:24 PM
Dear Thomas951
Thanks for your reply.
Here is the info you asked for
Front outer: LM11949/LM11910
Front inner: LM48548/LM48510
Rear: 2788A/2735X
Many Thanks
Hass
  #24 (permalink)
Old 30-05-24, 06:26 PM
Dear AndrewA
Thank you very much for your reply.
All is going to plan so far so i'm very happyof the progress !
Yes indeed if the 411 is ready in time I would love to attend in it !
Hope you and the motors are keeping well and busy !?
Best
Hass
  #25 (permalink)
Old 30-05-24, 07:09 PM
Hi Hass,
many thanks for your reply, I have added this information to the partslist, which is updated by Kevin, in the resource section.
I would love to hear from you if you could add anything to that list.
Thomas
Dear Thomas951
Rear: 2788A/2735X
Many Thanks
Hass
  #26 (permalink)
Old 17-08-24, 12:22 PM
Dear all,
I hope you are well.
I have finally finished the full engine rebuild for my 411 S4 !!
I've gone with the following for the rebuild
+.030" Flat top cast pistons 4.250"
Lunati Voodo High lift Cam
Edelbrock 2186 Performer intake
Edelbrock AVS 650cfm Electric choke carburettor
Custom S/S headers
Electric ignition
High flow aluminium water pump
Pertronix Flamethrower ignition coil
and a few more upgrades
All other parts on the engine are brand new - sparks, leads, alternator, gaskets, power steering pump etc...
Thanks !
File Type: jpg D4CBEE5F-06B4-43D2-810C-6AEF81A141EF.jpg (238.6 KB, 19 views)
File Type: jpg F4E911BA-D1B9-4BB9-B419-2708684ED258.jpg (196.6 KB, 21 views)
  #27 (permalink)
Old 17-08-24, 03:54 PM
Very interesting!
I have a few more questions:
-Which duration does the camshaft that you have used have?
-Roller camshaft or standard hydraulic lifters?
-Does these headers really clear the chassis rails? Who made them? Price?
-Cylinder heads are left standard?
Please report, maybe when the engine has run in, the fuel consumption.
Sorry for being so inquisitive..
Thomas
  #28 (permalink)
Old 19-08-24, 06:01 AM
Morning H
Glad to see you haven't resorted to doing things by half !
Look forward to first time you fire it up.
Best
1974, 383, 411, s4
