Window winder switches for411 wanted
Old 22-09-23, 10:37 AM
Default Window winder switches for411 wanted
I need 3 new window switches for my 411.A Lucas 35258 152SA looks like it might do the job but has the wrong type of terminals. They are available through Holden.They also show a switch for a Triumph Stag which could be the same as the Lucas one as mentioned above. Auto Electrical Spares show only one DAC2747 152SA once again with the wrong terminals.
Does anyone know the correct Lucas number and where I might purchase them from ?
Regards Peter Dowdle
Old 22-09-23, 10:48 AM
https://www.martinrobey.com
Try Martin Robey or other Jensen suppliers.
The switches used on SIII Interceptors are similar.
Old 22-09-23, 10:50 AM
If it needs blade connectors the earlier XJ6 one might be right.
https://www.sngbarratt.com/English/#...&saveBranch=UK
Old 22-09-23, 01:14 PM
Thanks Guys
The series 2 Jag switch looks well but is too wide for the 411
The jensen one doesnt look right
Old 22-09-23, 01:19 PM
Thanks Guys
The XJ6 S2 switch is the same width as the Lucas 35258 152SA, that you suggested, which is the switch for XJ6 S3. I think the S2 and S3 both have same size aperture for the switch. What are dimensions of the aperture on your 411?
Old 22-09-23, 01:36 PM
I wasnt sure about the size of the ones I spoke of I couldnt find any specs
on them.
My 411 measurements are approx 43 by 27
Mine is a series 2 the series 1 had wind up manual windows and the 3 4 & 5s
I have no idea.
Some one has fitted aftermarket switches that are shorter and narrower but
fit nicely into the old switch case which they vandalized so I am running a
little blind
Old 23-09-23, 01:35 AM
Default Lucas Blade Window Switches
Hi Peter,
Perhaps take a look at the Barnfind Spare Parts website. The Lucas Original switches range from $50-$65 Working, the measurements appear the same as what your talking about.
https://www.barnfindspareparts.com.a...+window+switch
Cheers for now
Pete
