| 8 & 10 cyl Bristol cars Type 407 onwards - restoration, repair, maintenance etc |
			 I need 3 new window switches for my 411.A Lucas 35258 152SA looks like it might do the job but has the wrong type of terminals. They are available through Holden.They also show a switch for a Triumph Stag which could be the same as the Lucas one as mentioned above. Auto Electrical Spares show only one  DAC2747  152SA once again with the wrong terminals.
	Does anyone know the correct Lucas number and where I might purchase them from ? Regards Peter Dowdle  |
			 https://www.martinrobey.com
	Try Martin Robey or other Jensen suppliers. The switches used on SIII Interceptors are similar.  |
			 If it needs blade connectors  the earlier  XJ6 one might be right.
	https://www.sngbarratt.com/English/#...&saveBranch=UK David  |
 The XJ6 S2 switch is the same width as the Lucas 35258 152SA, that you suggested, which is the switch for XJ6 S3. I think the S2 and S3 both have same size aperture for the switch. What are dimensions of the aperture on your 411? David Last edited by dwomby; 22-09-23 at 12:32 PM.  |
	I wasnt sure about the size of the ones I spoke of I couldnt find any specs on them. My 411 measurements are approx 43 by 27 Mine is a series 2 the series 1 had wind up manual windows and the 3 4 & 5s I have no idea. Some one has fitted aftermarket switches that are shorter and narrower but fit nicely into the old switch case which they vandalized so I am running a little blind Peter  |
			 Hi Peter,
	Perhaps take a look at the Barnfind Spare Parts website. The Lucas Original switches range from $50-$65 Working, the measurements appear the same as what your talking about. https://www.barnfindspareparts.com.a...+window+switch Cheers for now Pete  |
