Engine Number
Old 16-11-20, 02:38 PM
AndrewA AndrewA is offline
Default Engine Number
My cars had an engine change at some point. The engine number that's on the V5 is C318-03-15AJ.
Found this on the internet "The US-built 1967 LA 318 has engine number prefix C318, while the Canadian 1967 poly A 318 has engine prefix CC318. (The first ā€œCā€ stands for the 1967 model year; the second ā€œCā€ in the poly engine stands for Canada.)"
So it looks like I've got the later engine. Any idea what the rest of the numbers/letters mean?
Old 19-11-20, 01:14 PM
Default Engine Number 318-03-15AJ
Andrew,
according to the BOC Chassis list, engine number 318-03-15QAJ was fitted to a 410 registered AWR 740G.
The engine number you give is not listed in BOC records with a C or CC but appears in sequence and appears to have been fitted to chassis number 7461 from new in a MAROON 410.
I hope this helps, it is according to the records a perfectly std engine fitted in 1969.
For some reason there is a note that the car has been rebuilt as a std saloon, (very odd)
Old 19-11-20, 01:21 PM
Thanks for the reply - appreciated.
