Anti-roll bar Bristol 410
Old 03-09-20, 02:50 PM
Default Anti-roll bar Bristol 410
Can anyone offer some advice please before I start to strip down the front end of my 410.
The problem I have is to the anti-roll bar fixings. The area in question is at each end of the straight section of the roll bar, this is where the rubber bearing and bearing clamp are (indirectly) attached to the chassis. There is a small box section of steel welded between two pieces of tubular steel to which the bearing clamp is attached. The steel to the box section has corroded on both side of the car to the point it needs replacing. I don’t think this part is available off the shelf, so I intend removing the offending parts together with the associated brackets etc and have new ones made. I intend to do one side at a time.
Do any members have a detailed drawing of the part in question of even old ones which I could use as a template before striping the front of my car down. Any advice or help will be very much appreciated.
Brian
Old 25-10-20, 09:03 AM
Not sure that helps a lot, but here are pictures of a very rusty 410 roll bar
Old 27-10-20, 01:11 PM
Thanks for the photos, unfortunately the photos don’t help me. Ideally, I would like photos or a detailed drawing of the actual part or even an existing bracket that has been removed from a 410 which I could use as a template. The obvious risk of using an old bracket as a template is that it may be distorted if the car it came from had been involved in a front end shunt.
I will probably start the removal of my existing brackets sometime in November once they start spreading salt on our roads.
I will post a few photos of the offending part once it’s removed and hopefully the new replacement.
Old 21-11-20, 06:04 PM
Zorglub,
Thanks once again for the photos you sent, if it’s not too much trouble are you able to take another photo from ground level looking up to the underside of the anti-roll bar bracket, please? This would certainly help when I reconstruct the framework.
Now that I have removed the radiator and cover plates etc. I have a very clear view of the problem.
My 410 has previously had the mounting brackets for the anti-roll bar replaced. Who ever did those works appears to have cut out the existing brackets back to good metal on the adjoining tube framework and welded in the new brackets in a “near enough” position. This position resulted in one of the fixing bolts on each side of the car being almost inaccessible. The only area of the tube framing and anti-roll bar brackets that has corroded is the actual bracket, all other adjacent steelwork is sound. The problem as to the cause of the corrosion is two fold. Firstly because the repairs were done in-situ any paint that had been applied to the bracket will have burnt off and the repainting would have not been adequate. Secondly, the brackets as installed (this may apply to other Bristols and should be checked) form a “cup” without any drain holds which will hold water and allow the brackets to corrode from the inside, as mine has done.
I have attached a few sad photos of the affected area, it can be clearly seen the areas in question and the misalignment of the tubes.
I will post a few more photos once everything is removed.
File Type: jpg 7AFFD796-9874-4D93-AFE3-46958261B883.jpg (195.4 KB, 42 views)
File Type: jpeg 1B50C760-74A3-4138-98A2-AD61FF4FC574.jpeg (266.2 KB, 34 views)
File Type: jpeg 3330D0AB-7954-49AE-8EBA-7A17179CB449.jpeg (263.0 KB, 36 views)
Old 22-11-20, 12:00 PM
Dear Brian
I ended up using a 411 anti roll bar rather than the set-up for the 410 - mostly because BCL could not supply me with anything else at the time. You need to do a few modifications for the 411 bar to fit: mostly drilling four holes into the chassis and inserting steel rivet nuts. I originally used aluminum in 5mm, and then moved to steel inserts in 6mm. I am attaching a few pictures to illustrate this. Hope that helps
Old 22-11-20, 12:03 PM
You can see circled in red the attachment points
Old 22-11-20, 12:55 PM
Dear Zorglub,
Yes, it certainly does help, I am assuming that you have fitted the roll bar on the rear section of the lower wishbone, is that correct?
If you have fitted it to the rear of the lower wishbone, was there sufficient clearance between the engine sump and the exhaust downpipes? Were you able to reuse the existing lower wishbones?
I hadn’t thought it possible to upgrade to a later model, I will be making a few phone calls in the morning for parts availability and costs.
It’s also my intention to replace the rubber bushes on both the upper and lower wishbones during these works, working on the principle that they haven’t been done for very many years and it’s probably easier while the car is partially stripped down in this area anyway.
Old 22-11-20, 12:58 PM
Sorry, I posted a reply before seeing your second posting which answered most of my queries.
Old 07-07-21, 03:28 PM
Bristol 410 Anti-roll bar update
I thought I would provide an update of the works to the front suspension on my 410. As noted sometime ago, I had corrosion in the brackets supporting the ant-roll bar. Initially, I was intending just to replace the brackets and renew the rubber bushes. The existing brackets on my car showed signs of previous patch repairs, I wanted to renew them completely but was unable to obtain replacement sections or even an existing section I could use as a template prior to dismantling my car.
Zorglub made the suggestion that I could upgrade the position of the ant-roll bar to that on a 411. This made a lot of sense to me for a number of reasons.
As with all of these jobs on old cars you will make decisions to replace other parts in the process and this is precisely what I did in the hope of not revisiting any issues in the vicinity of the front suspension whilst in my ownership.
The works involved the complete strip down of the front suspension and replaced, renewed and upgrading the following:-
Coil road springs, rubber donut and large steel retaining “washers”
New coil spring pans were used as part of the upgrade to the 411
Replacement anti-roll bar and bushes etc. also from a 411
Suspension struts were sent away for checking and servicing
Upper and lower ball joints renewed
Brake calipers sent away for refurbishing, new pads, flexible brake hoses and copper brake pipes.
New outer track rods and ends
Replaced all the wishbone bushes.
Replaced all nuts, bolts and washers with new; washers were a rarity on my front suspension for some unknown reason.
The small brackets which attached the bottom of the suspension struts to the coil spring pans were cracked (a common fault I believe), replacement brackets were expensive for what they were, so new ones with a much improved design were made for a less than £10.
Doing these works, the following changes and hopefully improvements were made:-
I replaced the 4 LH outer track rod ends and track rods to the more conventional 2 LH and 2 RH outer track rod ends and track rods; this simplifies the tracking into a very small and quick job.
As mentioned above the lower strut brackets were upgraded to an improved design.
The 1/4” bsf nuts, bolts and washers to the inner brackets of the upper wishbone were replaced with 5/16” bsf bolts.
The area of the original anti-roll bar brackets was taken off and the corroded areas cut out and new section of steel plate were inserted to provide additional rigidity, as these brackets support the front bumper.
Everything in the area I was working in was taken back back to a sound surface and treated with 2 coat of primer and two top coats of black paint, plus prepare and touch up the under seal in the same areas.
The central track rod ends, wheel bearings and oil seals all appeared to be ok, so these were left untouched.
In addition to the above I had the rear brake calipers refurbished, new brake pads, one new copper brake pipe and two new disc brake shields (these were made in my workshop for a material cost of £2).
To summarise the works, having completed approximately 500miles in the last couple of weeks my car is driving very well and the handling excellent. I also had the car MOT’d with a pass and no advisories plus a few complementary comments by the examiner.
Special thanks to Zorglub for pointing me in the direction of the anti-roll bar upgrade and also to SLJ who helped me out of a few very sticky corners with their expertise.
Old 08-07-21, 05:27 AM
Thank you very much for the kind words. Very happy it turned out well. Please post some photos.
I am intrigued by your track rod ends setup:
- could you share the provenance of the LH and RH replacements
- does anyone know why the initial setup was mostly LH and not 2 LH and 2 RH
I have the original all LH setup and alignment was to both tedious and un-precise
Old 08-07-21, 03:02 PM
Thanks for your update - really helpful .After another look at the bushes, whilst they're OK as far as one can tell I've decided it's a false economy not to change them. I want no surprises from the front suspension for the foreseeable either so it makes sense to go right through it.
I too am waiting with baited breath to hear more about the LH/RH track rod ends.
Old 09-07-21, 09:24 AM
My understanding of tracking a car with two LH track rod ends (tre) on each side of the car is to release one tre on each side and turn the tre until you think it’s in the correct position then refit it, after which you need to check the alignment again; if it’s not correct, repeat the process until it is. This needs to be done on both sides of the car. The tow in/out of the front wheels is adjusted by the central track rod in the traditional manner because the central track rod has one LH and one RH tre.
When I reached the point initially to replace my tre’s, the first problem was to remove the old ones from the track rods. After trying all the usual tricks to release the ends from the rods, this became a challenge, including using 24” stillsons and a very heavy duty vice. I decided at that point to replace the rods with new ones and go for a more conventional installation as is fitted to my other cars, in fact all cars I have ever owned (I think).
As most readers will know, when fitting a LH and RH tre onto a rod threaded accordingly at each end, you only need to turn the rod to move the tre’s in and out. The tow in or tow out can also be done at the same time. This process eliminates removing the outer tre to carry out the adjustments and also negates the need to adjust the central track rod.
I set up my alignment initially with a length of string during the assembly process before trailering the car for tracking to my local garage for it to be done accurately.
I am sure Bristol Cars had a very good reason for using the 4LH tre; if anyone knows the reason why, I would be interested. I suspect a lot of Bristol owners will have already made this modification.
I will take a few photos and post them quite soon, the delay is because I have had to remove the wiper motor this week, three of the wires coming out of the motor have shed their insulation due to old age and whist doing that job, I decided to have my tachometer upgraded for compatibility with my electronic ignition and also have the clock repaired which hasn’t worked in my ownership plus a few other “small” jobs while waiting for the return of the Rev counter.
Andrew, if you are considering replacing the bushes on the wishbones, check very carefully for hairline cracks in the wishbones and if in doubt, have them crack tested.
Brian
Old 26-11-21, 10:28 AM
Hi Brian,
I would love to find out we’re you got the lh/rh threaded track rods from.
Kind regards
Thomas
Old 26-11-21, 04:46 PM
Hi Thomas,
I bought them from a company called Amsteer Sale Ltd, they are based in Staffordshire.
Excellent company to deal with, very helpful.
Amsteer Sales Limited
Unit 17 Ariane
Lichfield Rd Ind Est
Tamworth
Staffs
B79 7XF
Brian
Old 26-11-21, 05:08 PM
I used them recently thanks to Brian (and others) recommending. I sent them my old tie rods and track rod ends a few months ago and they sent back nice new LH/RH ones - took about a fortnight and cost circa £150 for all 6 track rod ends and making up two rods.
For what it's worth I also got a selection of camber shims from Classic Bristol Car Parts so I could get that spot on when the alignment was being done as well.
Old 26-11-21, 09:15 PM
ANDREW
I agree with you about Amsteer, some time ago I ordered a new set of tie rod ends for a 411 as they were showing signs of age.I did this without knowing of the double left hand thread issue. The set arrived and I set about fitting them only to find that I had been supplied with left and right combinations ( why Bristol did the double LH system I have no idea). I contacted Amsteer and they at that stage knew nothing of the problem but to their great credit sent me 2 new left handed tie rod ends at no cost to me and told me not to worry about returning the others.I cannot speak to highly of the service they provided.
I had no idea they would manufacture the RH replacement arms, what a great way to go it would make wheel allgnment so much easier and more accurate.
