B400 - engine stalled after sudden braking
Old 02-06-25, 04:44 PM
Bela Bela is offline
Default B400 - engine stalled after sudden braking
Yesterday, at 34°C (93°F) air temperature, I had a problem with my B400: the engine stalled after sudden braking. Afterward, I was able to start the vehicle by pulling the lever on the fuel pump. I wouldn't have expected this, since the fuel is still being flushed from the front. However, there's a short segment after the fuel pump toward the tank.
I've had the vehicle since 2019 and have never experienced this behavior. Is this a known issue?
Old 02-06-25, 08:29 PM
Stefan Stefan is offline
Default Bristol stalls on heavy braking
Mine does that occasionally, it’s just because the fuel in the float chambers tips forward , away from the jets. Itll restart normally afterwards.
. It’ll also happen on cornering at high speeds eg really, really fast round a roundabout, or on the circuit, for same reason. The engine cuts out briefly and spectators may report a flash of flame from the exhaust. Vroom vroom!
Old 02-06-25, 08:40 PM
Originally Posted by Stefan View Post
Mine does that occasionally, .....Itll restart normally afterwards....
If I could start normaly and rapidly - no problem. But in this case I must leave the cockpit. What makes the difference?
Old 03-06-25, 07:52 AM
You might consider checking the condition of the pickup screen on the tank unit in case that is slowing fuel delivery to the pump. Modern 10 % ethanol fuel supposedly does long term harm to some of the copper based components of the fuel system. The screen on my 403 had all but disintegrated and I spent quite a while blaming the carburettors for poor throttle response before the real problem was diagnosed by Coleman Classics.
Old 03-06-25, 03:36 PM
I can't find a pickup screen near the tank in the parts list. But I did find one in the fuel pump. I'll take a look.
Old 03-06-25, 04:02 PM
My 400 is non standard so I can't help with specifics but I think the fuel take-off from the petrol tank will be removable with some sort of a tube with a mesh strainer at the bottom. that's what I am calling the pickup screen.
